Use for JB Weld ?
achodges1
08-04-2005 20:25:28
Has anybody out there used JB Weld to fill seal grooves on slow turning shafts? The bull pinions on my super c have a preety good groove where the seal for the brake runs. Thought I might give it a try. Surely I'm not the first one to think of it.
achodges1
08-05-2005 21:53:24
 Re: Use for JB Weld ? in reply to achodges1, 08-04-2005 20:25:28
Thanks for all the input. Think I'll look for a sleeve. If I can't find one I'll give the JB Weld a try and see how long it lasts.
Mac
08-05-2005 05:25:43
Anyone tried filling pits in cyl rods and sanding even with surface?
DaveJ WI
08-05-2005 16:52:08
 Re: Use for JB Weld ? in reply to Mac, 08-05-2005 05:25:43
I just filled a scratch about .030 deep on a fork lift hydralic cyl., final sanding with 100 grit wet.It has been in daily use with the repair and new seals over 400 hours and no leak.
Andy Martin
08-05-2005 05:10:13
I think you'd have a real tough time getting the epoxy surface slick enough to not wear the seal richt out.
Merle Hoppenworth
08-05-2005 05:04:01
Take your shafts to your seal supplier and ask for a speedy sleeve, I think you would be more satisfied in the long run. It gives a real smooth surface for the seal to run on and a tight fit on the shaft.
CNKS
08-05-2005 05:03:21
JBWeld is strong, but is only for parts that don't move, the groove will eventually come back. I have replaced those seals in two tractors, a C and Super H, both were grooved -- since the new seals are narrower than the old leather ones, they will probably run in a slightly difference place and won't leak. Short of having them rebuilt, you can use a Speedy or Redi-sleeve, I would guess $50-$75 for that size shaft, but with slow turning, they will last for years.
300Randy
08-05-2005 05:00:14
Besides roughing it up be sure its as clean as you can get it. Wipe it down with acetone or alcohol.
1031D
08-04-2005 22:07:42
I have a 1954 CASE VAC and the end cap for the steering box cracked out-it is similar to the big bearing retaining nut on my Farmall C and your Super C in the same spot. I built it back up with DEVCO? 2ton 2-part clear epoxy, filed and milled it to size and shape, not a lick of trouble. I have used JB weld to plug holes and seal cracked water jackets, but not shafts yet. I DEFINALTY RECOMMEND GETTING THE SHAFT AS ROUGH AS POSSIBLE SO IT STICKS!!! If you don't, it will just peel right off. Just my 2 cents
James2
08-05-2005 07:44:46
 Re: Use for JB Weld ? in reply to 1031D, 08-04-2005 22:07:42
Devcon, similar to but better than JB weld. Devcon also makes a titanium version. This titanium stuff looks odd because it will not be black. I believe it is a little stronger than the steel/iron stuff. Great stuff, darned expensive.
