Coverting 2pt to 3pt.
DaveJ WI
08-05-2005 16:45:51
What do I need to convert the 2 point on a 300 Utility to a 3point ? I am thinking about buying one that has a 2pt . Thanks in advance.
RayP(MI)
08-06-2005 17:05:03
 Re: Coverting 2pt to 3pt. in reply to DaveJ WI, 08-05-2005 16:45:51
Try worksaver.com They have conversions for many IHC 2pts. Their site has nice drawings that will give you ideas as to how they constructed theirs. Have a set from them on my Framall 200, has been satisfactory.
Geoff NY
08-06-2005 12:23:39
Reading some of the replies tends to confuse things. Basically there are 2 types of adapters that have been around since the 50"s. One type is a unit that includes the top link, and the other is just two prongs with the balls on each that requires a top link. IHC made a sweet top link or fabricate your own.
KIP in MX
08-06-2005 12:03:06
Donīt know about the 300, but when we got the 3 point kit for our 240U, it had the prongs and a top link mount plate that replaced the plate above the PTO.
Scott Medlock
08-05-2005 17:01:14
Easy...
On this website, at your Case/IH Dealer, or a bunch of other places you can get a set of "Conversion Tongs"...
New one are about $100 ea... I got a set of old ones from my local IH Dealer for $30 each... Plug em into the FastHitch and you've got 3pt.
And can just pull them out if you've got some FastHitch equipment. I use em on my 300U for my finish mower, brush hog, etc. and drop them out to use my plow, disk, etc. that's FastHitch.
Scott
ny bill
08-06-2005 05:14:30
 Re: Coverting 2pt to 3pt. in reply to Scott Medlock, 08-05-2005 17:01:14
what about the top link mount? cost extra or have to fabricate one?
DWV
08-06-2005 18:12:01
 Re: Coverting 2pt to 3pt. in reply to ny bill, 08-06-2005 05:14:30
The 300 U with factory 2 point came with top link
mounting place.
Loren
08-06-2005 08:20:18
 My 300 has one. in reply to ny bill, 08-06-2005 05:14:30
Hook it up and go.
steveormary
08-06-2005 10:36:59
 Re: My 300 has one. in reply to Loren, 08-06-2005 08:20:18
For 3pth you will need the top link and someplace on your tractor to hook it to. As the other fellow says you can get adapters to go from fast hitch to 3pth.
steveormary
Loren
08-06-2005 21:18:48
 Re: My 300 has one. in reply to steveormary, 08-06-2005 10:36:59
Since you posted under my post, were you letting me know this? I have a toplink and the mount is already on the 300U. Factory looking setup to me.
steveormary
08-07-2005 07:43:06
 Re: My 300 has one. in reply to Loren, 08-06-2005 21:18:48
Loren;
I just wanted to make sure ya"ll knew that with the 3pth you would need a top link. I had one FH implement and thought it was harder to hook up then the 3pt stuff. Enuf.
Have a good day
steveormary
