Hard Startin' IH
Allan in NE
08-06-2005 06:34:09
So,
Yesterday morning, I had trouble gettin' the old 686 with the 310 to start. Normally, it is running 'fore she spins over twice. Even had to give 'er a little squirt of either. It just acted like it didn't wanna go.
Worried all blessed day about that goofy tractor; is the pump going bad, loosing compression or what? Drove myself nuts frettin' over my favorite little tractor!
Then..... ....I just now happen to notice that it was only 49 degrees yesterday morn. Hmmmm, thought it felt a little chilly out there! :>)
Allan
Jimmy King
08-06-2005 22:00:15
 Re: Hard Startin' IH in reply to Allan in NE, 08-06-2005 06:34:09
Allan, I have two 310's 706 and 756 the fuel shut off will settle out in the sweet spot on the 706 when I shut it off just turn the key on a crank until about 30 degrees, the 756 doesn't, not that many hrs on a over haul and new pump needs either at 50 degrees.
Hugh MacKay
08-06-2005 19:56:35
Allan: Could you post a photo of yourself? First you worry about 966 bull gear whine, now 310 German diesel pump. You've been on that one before and there have been countless other worries in between. I'm just kind of curious as to what an old WORRY WART looks like? Quite sure I know a couple other old worry warts, and just want to compare, see if there are any outstanding physical features.
jossette
08-06-2005 17:16:09
third party image
finally got my fenders done. Boy do they keep the crap out of my face....
Illinois Boy
08-06-2005 09:35:09
Allan,
You have way to much work to do - instead you are-a sit'n in the air condition'n and look'n at a 'puter screen - please get busy or I'll have to tell the FFA you are-a slack'n out there in Neee-braskee.
Yep - noth'n like a brisk morn'n to steal the whump right outa yer dee-sell.
jossette
08-06-2005 13:53:51
 Re: Hard Startin' IH in reply to Illinois Boy, 08-06-2005 09:35:09
add a half gallon of super unleaded.
I know, but just try it...
Allan in NE
08-06-2005 16:50:53
 Re: Hard Startin' IH in reply to jossette, 08-06-2005 13:53:51
Yep, I hear ya.
It has straight #2 in it now too. Today it was warmer and the old sis popped right off.
Allan
jossette
08-06-2005 17:02:19
 Re: Hard Startin' IH in reply to Allan in NE, 08-06-2005 16:50:53
50 degrees?? still should have popped right off. I cant believe you would let your baby sit for more than day..
