574 TRANS.
irving.
08-06-2005 17:04:39
have broken lo rev. shifterfork at trans.on 574 tractor can someone tell me how to replace it. thanks RON BONE CAVE TN.
Bernard le mécano
08-08-2005 17:05:58
 Re: 574 TRANS. in reply to irving., 08-06-2005 17:04:39
Hi Irving, i have changed many of those parts, at the Case-IH dealer, where I have worked for. You can remove the lever and replace it by the left side of the rear train. Just train the oil, remove the MCV control valve ( the plate that hold the hydraulic pump and filter) With a short 7/8 open wrench, loose the sealed nut, remove the broken shaft and place the new one. It have a big spline for the timing. Just aling the short lever with the fork. Bernard le mécano Québec Canada
JB2
08-06-2005 18:55:43
Hi Irving, I have I&T shop service manual for 684 which has same transmission as 574. As Tractor Vet says it is a major repair. The range transmission is under the seat and fenders, fuel tank, seat and 3pt lift arms all have to be removed to remove the top cover of range transmission. The top cover includes that big chunk of cast iron from the back of the tractor all the way to where the step thru is.
JB2
the tractor vet
08-06-2005 18:33:58
Well you are in for some work as ya got to pull the top off and the fueltank fenders seat and anything else that is in your way . It's a fun job i have only done one and it has been awhile maybe 13 years ago . Get yourself and IT manual and a 12 pack .
