Farmall Regular Carburetor Parts
Heywood
08-07-2005 06:53:25
Are parts available for Farmall Regular Carburetors? What are the little oil ports for on the top of the engine? Thanks
KevinH
08-07-2005 08:11:57
 Re: Farmall Regular Carburetor Parts in reply to Heywood, 08-07-2005 06:53:25
There are 4 "ports" on top of the engine. 2 are in the valve cover and are where you put oil into the trays that disperse oil to the valve train since the Regular does not oil the valves itself. The other 2 are pipes that go directly into the head and are topped with small cups. This is for priming the engine with gasoline.
Paul G. in Mn
08-07-2005 17:14:55
 Re: Farmall Regular Carburetor Parts in reply to KevinH, 08-07-2005 08:11:57
I seen kinda a nice set up on a very late F-20 that had a petcock coming out of the oil filter houseing that had a line feeding those 2 ports on the valve cover. It was so you didnt have to manualy oil the tappends. It looked factory and think I am going to make the same setup on my f-20
