330U Steering
Tweeter
08-07-2005 09:23:42
I took my manual steering box off the 330 to clean all the grease off it. After being cleaned I found that the grease is coming from a small hole at the bottom of the steering tube that runs up through the dash to the steering wheel. The grease seems to be oozing out little by little.
TDK
08-07-2005 21:02:38
 Re: 330U Steering in reply to Tweeter, 08-07-2005 09:23:42
There really shouldn't be any significant amount of grease in the tube. The only thing that gets greased in the tube is the upper bearing. A little wheel bearing grease will do here. Everything else is inside the gearbox where it gets it's lube. I think that the hole is to drain any moisture that might get in.
