Utility Tractor with loader
Nathan in Texas
08-08-2005 07:45:09
Well, I am very happy with my M and I have ended up using it quite a bit more than I would have expected. Brush hogging, blading my driveway, etc.
Now I've got the itch to get a tractor with a loader on it. I've been looking for something fairly small with a loader in the "under $4,000" category and can't seem to find anything locally. I've seen some 300 Ute's in the $3k range but without a loader. I want live hydraulics and would like to have a 3 point so I could use that tractor for road work and the loader and use my M for field type work with the mower and possibly in the future discing and stuff like that.
I really don't need a loader tractor, but talking with friends they said that I would be amazed at all the things I would find to use it for if I had one. I am not sure about putting a loader on the M but have thought about that option as well. I live on 42 acres and my driveway is about 1,500' long.
Any recommendations other than be patient and keep my eyes open? Should I stick with Red or be open to look at other brands?
Thanks for any input.
Nathan
rumplestiltskin
08-12-2005 19:44:09
 Re: Utility Tractor with loader in reply to Nathan in Texas, 08-08-2005 07:45:09
I own a 300 Utility, but would not necessarily recommend putting a loader on one. The steering gears are notoriously substandard (to put it kindly), and as a result are becoming hard to find. And with non-power steering, you just about need a pipe wrench to turn the blasted thing -- until the gears fail, of course.
If I were looking for a loader tractor, I think I'd look somewhere else.
Mark W.
old
08-08-2005 08:17:48
If I where you I'd look at all the colors. But I do have a lot of colors when it comes to tractors. The 300U will probably have live hyds and live pto but they do have a problem with steering being hard and if you put a loader on you will want power steering.
