Temperature Gauge Probe Mount Broken
Flatland Farmal
08-08-2005 17:29:08
Here's the problem, while removing the temperature probe from the head. the mount (I think it's a 3/4" fitting) broke off at the cylinder head. Need to find out how to remove the remainder of the fitting. The originag temp probe has a fitting that screws into the broken fitting. Will also need to know where to aquire a new cylinder head fitting.
jossette
08-11-2005 19:13:26
 Re: Temperature Gauge Probe Mount Broken in reply to Flatland Farmall, 08-08-2005 17:29:08
did you get the gauge in the old girl??
any other questions I will try to answer..
Have a good time farmall'in
CNKS
08-08-2005 17:48:52
The fitting is just a pipe fitting. Any decent hardware store should have one. If the gauge and sensor don't work, OEM type ones are available from many places.
Bob
08-09-2005 06:49:28
 Re: Temperature Gauge Probe Mount Broken in reply to CNKS, 08-08-2005 17:48:52
The fitting is NOT just a pipe fitting. Even though it looks like a pipe thread reducer bushing, the internal thread is different, and there is a "step" or "ledge" down in the fitting the the lip on the thermal bulb seats and seals against.
You should be able to order a replacemetn through the CNH dealer.
Flatland Farmall
08-09-2005 09:47:08
 Re: Temperature Gauge Probe Mount Broken in reply to Bob, 08-09-2005 06:49:28
Will keep that in mind. I do have a mess that looks like I wil have to cut it out using a modified hack saw blade.
Flatland Farmall
08-08-2005 17:53:36
I'm going to try to chisel it out without damaging the threads. Thanks for the info. After removal I will pay a visit to the hardware store. Wife says I have to get it fixed by Friday.
jossette
08-08-2005 17:37:28
if it is not broke off to far inside, a small chisel and hammer works.
I believe you have to buy the whole unit to get the fitting, these days..
I do have one from a previous fix if you need one..
Flatland Farmall
08-08-2005 17:46:36
 Re: Temperature Gauge Probe Mount Broken in reply to jossette, 08-08-2005 17:37:28
Thanks for the quick reply. Didn't want to go in with guns blazing and make a mountain out of a mole hill. Want to geep the damage to a minimum. I will most likely be willing to take the spare fitting off of your hands.
jossette
08-08-2005 17:36:17
