Order Farmall Cub Parts Online
Farmall Cub Blade parts
Larry Hardesty
08-09-2005 06:30:48
Does anyone have a Cub grade blade from which I can get dimensions? I have the grader blade and the frame but not the metal to attach it to the Cub I have. Near as I can tell from pictures, I need the following pieces, which I think I can fabricate or get fabricated:
1) Rear lifting rod (older Cubs) or metal bar that goes from bell crank (touch control rocker arm) to lifting lever (part 650 135 R1)
2) Lifting lever (must be 3/8 steel about 30" long and 3" wide but I cannot tell from pictures) (part 650 146 R3)
3) Front lifting rod (ocer Cubs) or metal bar that goes from lifting lever to blade frame. Newer cubs have a spring arrangement to take care of shock from blade (part 650 136 R2--for rod)
4) Left Axle Brace (looks like 3/8 steel about 36" long and 3" wide and bent but I cannot tell from pictures) (part 650 147 R1)
5) Right Axle Brace (similar to above) (part 650 148 R1)
6) Axle Mounting bracket (part 650 138 R1)
7) front axle hanger (part 650 145 R1)
Any help appreciated.
Thanks
Larry
Larry Hardesty
Kearney, Nebraska 68849-2240
308-865-8535
308-865-8722 fax
hardestyll@unk.edu
Charlie V aka F20II
08-09-2005 08:36:50
 Re: Farmall Cub Blade parts in reply to Larry Hardesty, 08-09-2005 06:30:48
Howdy Larry, I'm going to be out to my partners place today getting some parts for a friend an will take some pictures of a blade an assembly he just got this weekend with a Cub he bought. I will email them to you this evening. I as well have bought a 1953 Cub last week to add to the other 22/23 tractors I have LOL. Been by your
exit in NB a number of time in the last few months but have not had time to stop - Chuck
Larry Hardesty
08-09-2005 09:41:11
 Re: Farmall Cub Blade parts in reply to Charlie V aka F20II, 08-09-2005 08:36:50
Chuck, Sounds great. Can you take some measurements too. Happy to have you stop by sometime. My collections is kind of scattered right now, but happy to show you what I do have.
Thanks in advance. Larry
