oil pressure gague tube leaking
super_m
08-09-2005 12:16:15
on my super m the little tube that goes from the block to the oil pressure gauge has a little stream of oil spraying out of it. what caused this? will duct tape or jb weld fix it? if not what will?it is just a small hole
Hugh MacKay
08-10-2005 02:51:54
 Re: oil pressure gague tube leaking in reply to super_m, 08-09-2005 12:16:15
Do as others have suggested. All I can add to this is do it soon as that SM oil pump, putting out a stream, could soon pump the crankcase dry. After that it will be a bit more that a $10. fix.
old
08-09-2005 14:04:25
Fix it right don't take a chance on tape etc. Most of them are just 1/8 or 1/4 inch copper tube, you should be able to replace it for less then $10 and have no worrys about blowing up and engine
El Toro
08-09-2005 12:34:31
You need to replace that tubing. Is it 1/4" copper tubing? Easy to replace. Hal
