M -- My oil and temp gauges kaput
E-manhunt
08-09-2005 13:33:56
I put new oil and temp gauges on my M -- the old ones didn't work. Well, the new ones don't work either. Is there some trick I am missing? The removal and installation seemed to be rather straightforward.
thanks
jossette
08-09-2005 19:49:05
 Re: M -- My oil and temp gauges kaput in reply to E-manhunt, 08-09-2005 13:33:56
get the clear plastic line for the oil gauge, it will tell you pressure or not on any given day..
water gauge... is there a thermostat in it???
Yugrotcart
08-09-2005 15:00:15
I agree, take of the oil line and fittings and blow then out, bet something is plugged with crud. As for the temp gauge, unless you are working it, it will barely move. Takes a lot to heat it up.
Yugrotcart
08-09-2005 15:01:27
 Re: M -- My oil and temp gauges kaput in reply to Yugrotcart, 08-09-2005 15:00:15
Seems the Cowman and I were typing at the same time..... ..... ..... ..... .
Nebraska Cowman
08-09-2005 14:59:26
I'm with capn'k Oil line might be plugged, lots of old Ms around with the thermostat removed. unless u realy work the tar out of them on a hot day they will still run colder than a witches heart.
captaink
08-09-2005 14:25:45
Check to see if the oil presure line is plugged. I'd take it off at the block and blow it out and make sure that the port is open. As far as the temp guage, if it is the factory one with the bulb on the end it might be working and indicating that your engine is not warming up as it should possibly
Farmall Don
08-09-2005 13:49:23
You didnt over tighten them, did you? That will ruin them.
