W6 Shutter Arm
Yugrotcart
08-10-2005 15:03:56
This vertical inside arm (by the oil filler cap)on my shutter control is slipping on the cross shaft. It's a tight spot to get at and need to know if it is keyed or just loose. I see no mention of this in my sevice manual.
DWV
08-11-2005 06:58:44
 Re: W6 Shutter Arm in reply to Yugrotcart, 08-10-2005 15:03:56
Ones I removed have keyway in shaft and special washer in center of inside arm goes in keyway.
jossette
08-10-2005 17:02:40
should be a 7/16 wrench top and bottom. just a slotted shaft with the bolt on one end....
Yugrotcart
08-10-2005 17:45:41
 Re: W6 Shutter Arm in reply to jossette, 08-10-2005 17:02:40
Thanks, I'll tighten it up and that should fix it.
jossette
08-10-2005 19:04:41
 Re: W6 Shutter Arm in reply to Yugrotcart, 08-10-2005 17:45:41
what I did on my 400 is take all of that apart at the oil fill and on each end of the cast I carefully drilled and tapped in some grease serks. No more trying to crank the rod off because of some rusty crap..
