Farmall F-12/14 Serial Numbers
DA@STL
08-10-2005 17:39:57
I bought what I thought was an F-14 about 3 years ago. I have fully restored it to the point where I'm ready to put the decals on it. But, I'm confused. The tractor has all of the looks of an F-14, but the serial number indicates it is an F-12. The engine block even has the same serial number stamped on it. I have not checked the RPM rating yet. The RPM for an F-14 is about 250 RPM higher than an F-12. The serial number indicates it is an F-12. Could someone have installed an F-12 engine and the front mounting plate for the gas tank in this tractor? Maybe I'm being too picky but, all of the research I've done indicates the serial number is for an F-12. And I know IH had reserved a certain number of tractors for field conversion from F-12 to F-14, but my serial number is way too low. Any comments?
Ed Topel
08-10-2005 19:16:17
 Re: Farmall F-12/14 Serial Numbers in reply to DA@STL, 08-10-2005 17:39:57
I've got a couple of F-12's like that. Somebody updated yours with F-14 parts. If you get the chance to drive a F-12 you can easy understand why. Moving the steering wheel up a little and getting the brake levers up from next to your ankles makes a big difference in comfort even just driving the tractor for an hour in a parade. Now imagine being in the seat 12 hours a day. I don't think it takes anything away from the tractor, it's just part of it's history. Have fun, Ed
John M
08-10-2005 17:48:20
Then I would say that you have an F12 with some farmer mods to it. Does the engine have a breather on the valve cover?
DA@STL
08-11-2005 06:25:38
 Re: Farmall F-12/14 Serial Numbers in reply to John M, 08-10-2005 17:48:20
Yep, it's got a breather out of the valve cover and fastened to the side of the block. I know what you mean about the difference between operating an F-12 and an F-14. What makes me believe it is an F-14 is because most of the part numbers for different items are for an F-14. What is confusing is it appears to be an F-12 according to the serial # 50049.
