Order Farmall Cub Parts Online
splitting cub
wayne7
08-10-2005 19:19:48
Trying to split International Cub at torque tube and transmission. Seems to be stuck, any advice on completing the split. All the bolts are out and the foot stand has been unbolted.
Rudi
08-11-2005 18:56:12
 Re: splitting cub in reply to wayne7, 08-10-2005 19:19:48
I hope you have read up on it in the GSS-1411 Service Manual. It is available on the Cub Manual Server as well as a ton of other information. Here is the url - www.cleancomputes.com/Cub/index.html
I have a feeling that it is probably stuck index pins... that was the problem on my 51... Course the steering could be a concern....
GooseCreek Farms
08-11-2005 03:20:56
First time I tried to split my cub I could only get it to seperate about a 1/4 to 1/2 inch. Studied it for 10 to 15 minutes and then took a break. Came back for a fresh look and quickly discovered that I had not disconnected the steering wheel shaft. "Couldn't see the trees from the forest". Good luck.
old
08-10-2005 21:00:00
Could be a number of things. Any thing from rusty guide pins to a bolt you missed, to a bad tranny shaft.
Buzzman72
08-10-2005 20:48:18
...battery cable...?
