Small Question...
AndyE.
08-10-2005 19:28:52
What is the tube that screws into the block that(i think)sucks up oil from the oil pan for the oil filter? I seemed to have broken it today moving my block to Pressure wash it. Any Idea where I can get one or do i have to fix the one i have? Thank you, Andy
El Toro
08-11-2005 05:53:13
 Re: Small Question... in reply to AndyE., 08-10-2005 19:28:52
I think you should post a picture of the item that you're referring to. Whats the tractor model. Hal
tn terry t
08-10-2005 19:54:54
 opps! in reply to AndyE., 08-10-2005 19:28:52
sounds like you just broke the oil pick-up tube
iester
08-10-2005 19:54:52
I think It is a drain,Maybe/
Peabody
08-10-2005 19:44:01
Andy, What tractor are you talking about?
AndyE.
08-10-2005 20:09:23
 Re: Small Question... in reply to Peabody, 08-10-2005 19:44:01
The farmall H. Do you know where I can get a new one or a cheap replacement?
Thanks alot guys!
Andy
kfox
08-10-2005 20:32:19
 Re: Small Question... in reply to AndyE., 08-10-2005 20:09:23
There is a short pipe nipple screwed into the bottom of the block on the H. Its just a drain for the rockerarms etc. I think its 1/4 inch black iron pipe. Just buy a new pipe nipple a little longer than the old one and cut the threads off the bottom end. ken
AndyE.
08-10-2005 20:54:01
 Re: Small Question... in reply to kfox, 08-10-2005 20:32:19
Well, Thanks guys! Ill see what I can do.
Andy
