Re: Engine stuck
old
08-11-2005 18:17:58
If I had it I'd fill the cylinders with tranny fluid and leave it a week or so. The I would try the starter again with the plugs out. Also be sure to keep the plugs in after filling it. If it turns over then good if not I'd then fill the cylinders with turpentine, not paint thinner but the real thing. Then I'd try the starter agin after a few days. Also each time you try the starter pull the plugs
