Flushing the radiator
Florida Tom
08-12-2005 11:08:14
Can someone give me the steps in properly flushing a radiator in 1958 Cub. I am told to run the motor while doing this.
Thanks
Yugrotcart
08-12-2005 16:20:27
 Re: Flushing the radiator in reply to Florida Tom, 08-12-2005 11:08:14
If there is a lot of crud in it, remove the rad hoses and flush out the block with a pressure washer. I had an MM Z that I had to do that several times to as it was full of rust.
old
08-12-2005 11:45:50
That depends on what you are really asking. If you mean spraying out the dirt on the out side or if you are talking out flushing out the in side of it. This is how I do the inside. I drain the system when cold, then fill with vinagar and run it for about an hour. Let cool and then drain again, Then with engine off I flush with a garden hose. If you can the best way it to make up an adaptor to hook the hose to the block drain and leave the cap off and let the water run for about an hour. Then refill with antifreeze and go.
