574 no hydraulic function
tee
08-12-2005 18:13:53
Help needed I put new brakes on 574 and now i have no hyd. functions at all have been thru the valve and pump and can see nothing wrong. But it will not pick up the oil from sump no oil in filter housing help someone please
Bernard le mécano
08-14-2005 08:40:50
 Re: 574 no hydraulic function in reply to tee, 08-12-2005 18:13:53
Hi TEE, loose the line below the hydrolic filter and start the engine, run until the oil flow, stop and tight the fitting. May be your pump have to much wear to prime. Bernard le mécano Québec Canada
