what do the casting codes mean
dieselman_52
08-12-2005 18:52:58
Can someone tell me about what year my cub is by the casting numbers? these are some of the casting numbers from my little cub..trsnmission housing # *3*4*S* Left bull gear housing # *3*15*S Engine # *6*25*T* Thanks for any help with this
Rudi
08-13-2005 03:53:28
 Re: what do the casting codes mean in reply to dieselman_52, 08-12-2005 18:52:58
Diesleman_52:
You really cannot tell what year your Cub is simply by decoding the casting dates, The best you can do is get an approximation. I can tell you though, that if nothing has been changed then what you have is either a McCormick-Deering Farmall Cub or a McCormick Farmall Cub. The difference being that in 1949 IH dropped the Deering name from most Farmalls and just used up the old stock decals before switiching.
Now your casting codes:
Transmission housing # *3*4*S* equates to March 4th 1949
Left bull gear housing # *3*15*S equates to March 15th 1949
Engine # *6*25*T* equates to the 25th of June 1950.
Ih typically used up most of a yearly casting production within about 6 months, so typically a set of March castings would be used up by September or October of that year. Your Casting Codes vary by over 15 Months which could equate to almost 2 years.. so quite probably your engine has been swapped.
In behind the Carb and just below the manifold is a boss that has the Engine Serial Number on it. Let me know what that is and we might be able to solve your question a bit further.
Also, there is a serial number plate on the front bolster just behind the steering rod entry to the steering box.
There should be an entry such as FCUB then a up to 6 digit serial number possibly followed by a J and then an 1800 which is the RPM's. If you can find that then you can tell for sure what year. If it is missing, the best we can do is an educated guess.
Bronson
08-12-2005 19:34:45
["S" stands for 1949] and ["T" stands for 1950].
jossette
08-12-2005 19:12:56
frame was built in 47
motor built in 48
dieselman_52
08-12-2005 19:42:17
 Re: what do the casting codes mean in reply to jossette, 08-12-2005 19:12:56
thanks guys how can you tell me where the serial number is suposed to be on this tractor. I just got the little machine and it seem to be orignal. but some body put a 12v coil on it and were useing 12v battery to start it. I think it may need some work on the mag to go bact to 6v. any help with advise on that ?
Peabody
08-15-2005 06:29:40
 Re: what do the casting codes mean in reply to dieselman_52, 08-12-2005 19:42:17
If its got a magneto, it doesn't care whether the starting system is 6 or 12 volt.
Rudi
08-13-2005 09:03:07
Did you get the email?
All the info you will need to do ANYTHING on your Cub is contained on the Cub Manual Server at www.cleancomputes.com/Cub/index.html. All the links to the other Dedicated Cub Forums are on the main page as well.
Let me know if you get the email...
dieselman_52
08-14-2005 13:48:22
 Re: what do the casting codes mean in reply to Rudi, 08-13-2005 09:03:07
Thank guys for all the help but i still can't find a serial number anywhere on this machine. But thanks to Rudi I know where a web site is that will tell me how to make some of the repairs i need to make on the two tractor i have. thank a lot Rudi
Yugrotcart
08-12-2005 20:40:02
You just need an H4 mag. "Magman" who posts on this site can help you out.
