230 farmall throttle
cc
08-12-2005 18:54:15
Went to mow some grass the other day and just after I took off the dang thing went back to idle.Moved the lever - nothing happened. Got down and looked . Found nothing. Went to other side and pulled on linkage from governor to carb.that worked but connection up front from one side to the other no longer connected.Any idea as to what I"m looking at? Is it time for the junk pile? Thanks in advance for any help!! Cc
Wayne Swenson
08-12-2005 21:02:35
 Re: 230 farmall throttle in reply to cc, 08-12-2005 18:54:15
Take the governor off ( it can be done without removing the radiator) and look inside. The governor spring may have broken or the drive-pin that holds the fork to the shaft may have worked its way out so the throttle has no effect on the carb.
Not very difficult to work on.
cc
08-13-2005 19:52:52
 Re: 230 farmall throttle in reply to Wayne Swenson, 08-12-2005 21:02:35
It was the spring and it did come off with out taking off the radiator. thanks
Hugh MacKay
08-14-2005 03:30:30
 Re: 230 farmall throttle in reply to cc, 08-13-2005 19:52:52
cc: I'll go with Wayne's thoughts. I know it looks as though it will not come off without removing rad, however with some patient manuvering it will come. While you have it apart check the condition of thrust washer. In fact going to that work I would replace both the spring and thrust washer.
jossette
08-12-2005 19:19:39
time to find a 5/16 washer and cotter pin and fix the linkage...
