typical compression values on M w/Kerosene head
Kevin Brooks
08-13-2005 10:10:17
Does anyone have any cylinder head compression values for a good running '51 M with Kerosene head. I want to do a compression check but want to have some comparative values. I know that cylinder-to-cylinder variation (or lack thereof)is more important than actual.
Any help appreciated.
Kevin Brooks
08-15-2005 11:19:43
 Re: typical compression values on M w/Kerosene hea in reply to Kevin Brooks, 08-13-2005 10:10:17
Thanks all!
Now I have something for reference. By the way, the head has number 6336 - I was told this was for Kerosene / distillate. I most likely will only burn 87 Octane gasoline, however. Hope this doesn't change anything?
Hermit
08-14-2005 04:44:01
According to GSS-1356, 96 psi for the standard engine and 92 psi for engines with an increased bore and flat top pistons.
JonM
08-13-2005 13:40:17
I had one with 4inch flat tops and 8777 cyl head, comp readings were 85 to 90, hope this helps.
CNKS
08-13-2005 11:02:41
Tune up info in the link says 95.
