400 won't fire
Corny
08-13-2005 11:39:38
I'm a rookie at this. Took the 400 I grew up on and wanted to fix her up. She ran pretty rough. She was set up for positive ground, 12v with a generator. I ordered the electronic ignition conversion kit along with a new coil. Had to order parts for a negative ground system cause others weren't available. So I reversed the battery, repolarized the generator, installed the electronic conversion parts along with new plugs. I was very carefull with marking things all the way since I removed the distributor to be sure all went back in lined up as came out. Started it up. Ran a bit eratic for about 10 seconds, blew out a couple exhaust flames and quit. Since then won't even fire but rolls over fine. Weird that when I roll it over (with a battery charger still - old battery) the amp gauge needle swings to charge vs discharge. Any thoughts or did I manage to mess up the ignition conversion? Thanks
corny
08-13-2005 15:56:24
 Re: 400 won't fire in reply to Corny, 08-13-2005 11:39:38
Did as you guys suggested and I believe the did the usual dumb thing of moving the distributor shaft after I had it out. Thought I marked it but obviously not. When I bring the TDC timing mark up to the point the rotor is NOT pointing to #1 plug cable. So I assume I have the pleasure of taking it out and playing with lining it up. Thanks for the help.
El Toro
08-13-2005 19:51:10
 Re: 400 won't fire in reply to corny, 08-13-2005 15:56:24
You may not be that far off. If you're at TDC on the compression stroke, gently pull the distributor out and move the rotor so it points
to the No1 plug wire and reinstall. Make sure your rotor is at No1 after installing the distr. Should start then. Hal
Corny
08-14-2005 12:01:43
 Re: 400 won't fire in reply to El Toro, 08-13-2005 19:51:10
Did as you suggested but still won't fire. I'll get another electronic unit as I assume I fried the first one since my Distributor was off by quite a bit. Tried the old coil in place and still no luck so must be the electronic. By the way, working by myself I found a neat way to know which revolution is TDC. I put a wine cork lightly in the #1 plug hole. When the mark on the crankshaft hit TDC and the rotor pointed to #1 my cork blow off. So that told me whether I was 180 degrees off. Was fun.
El Toro
08-14-2005 12:13:48
 Re: 400 won't fire in reply to Corny, 08-14-2005 12:01:43
That's a good idea when working by yourself using the cork. You should keep that engine at TDC until you get the new unit. Hal
El Toro
08-13-2005 13:45:52
You need to remove No1 plug and bring the piston
up to TDC on the compression stroke. Someone needs to hold their thumb over the plug until you feel compression. Slowly rotate the engine until
your timing marks are aligned. Then look at the rotor and see if it points to No1 plug wire in the distr. If not off, your electronic ignition may be at fault. Hal
Corny
08-13-2005 13:08:15
Would it make any difference how I installed the electronic ignition unit? Seeing there's a 180 degree difference in the 2 ways it could fit in the distributor. Or with 4 firing positions it doesn't matter? Thanks
old
08-13-2005 12:44:56
If you didn't switch the wires on the amp gauge when you change the way the battery is in that why it reads wrong.
makin'hay
08-13-2005 11:59:00
1st thing i would check is top dead center, if you have spark. make sure it is firing correctly. then go from there. good chance you have wires in wrong order.
