Farmall 200 disc brakes
Heywood
08-13-2005 20:02:23
Are Farmall disc brakes any good? I've heard that they are not very good because they glaze. Where is the best place to buy discs?
VOLfarmall
08-14-2005 05:14:24
 Re: Farmall 200 disc brakes in reply to Heywood, 08-13-2005 20:02:23
You will need to know the thickness of a new disk, (this is important) take your old disk down to a clutch&brake relineing shop and have clutch lining material installed on the disks,also clean the actuator, check springs, balls etc take a small side grinder with a fine disk and go over metal surfaces. Take the one that is on the tractor off check seal and replace if needed. This will work. I have 3 tractors with dry brakes Have done this to all of them. Will cost a little more ,but its well worth it
RAW in IA
08-13-2005 20:51:58
Unless they are worn badly, just take the glaze off with some sandpaper, clean up the steel plates good, and clean up the balls and ramps. You can put a litle never seeze or such on the balls when you put them back together and they should work fine. They should be cleaned probably every year to work best.
