Serial number on a OS4
Dominique Hay
08-14-2005 00:45:29
I have a Mccormick Deering OS4 I have ran the serial number on it in many diffrent ih books and comes to be a 1941 model. But I found a book at local swap meet that said the OS4 line didn't come out in tell 1945
CNKS
08-14-2005 14:07:41
 Re: Serial number on a OS4 in reply to Dominique Hay, 08-14-2005 00:45:29
Guy Fay's data book indicates that the first OS4 likely was not produced until Nov 30, 1944. Thus it could have been called a 1945 model. However, the first O4 was built in 1940. The O4 had the full set of orchard fenders, the OS4 did not. If your serial number is for a 1941, then you have an O4. Chassis serial prefix for the OS4 is OBHS, for the O4, OBH. Engine serial prefixes are the same as chassis with the addition of an M.
El Toro
08-14-2005 07:07:48
Under Research & Info to your left they were first
built in 1940. Hal
