International 300 U - How heavy is it for traileri
Ozzyruss
08-14-2005 10:10:44
Hi,
A quick question, anyone have any info on the weight of my international 300 Utility tractor? It has a front bucket and rear blade. The tractor model is the torque amplifier. Going to rent an equipment trailer to move it but I don"t know it"s weight.
Thanks
Russell
Scott Medlock
08-15-2005 10:11:34
 Re: International 300 U - How heavy is it for trai in reply to Ozzyruss, 08-14-2005 10:10:44
My 300U (no loader or blade, but has 1000lbs of rear wheel weights) tips the scales at 4,900 lbs....
Your mileage may vary.. But there's a start anyway.
Scott
Janicholson
08-14-2005 10:51:46
The model is 300 Utility. The Torque amplifier is a clutch type two speed auxillary transmission allowing 10 speeds forward and two in reverse. This feature is desirable, as is the option of a live power take off. (yours might have it).
PaulIH300 is close on the wt. add more abuot 800 (conservative high guess if tires are full of liquid, and/or wts. are attached to wheels). Jim N
PAULIH300
08-14-2005 10:28:07
I would guess 5-6,000 lbs.Are the tires loaded?
ozzyruss
08-14-2005 11:59:32
 Re: International 300 U - How heavy is it for trai in reply to PAULIH300, 08-14-2005 10:28:07
Hi Paul,
Thanks for your reply, yes the rear tyres have home-made (not by me) concrete weights I"m guessing to balance the front bucket.
I don"t suppose you know the HP th erear PTO can put out? If I get it running properly I"m thinking of adding a backhoe.
Thanks
Russell
PAULIH300
08-14-2005 13:55:16
 Re: International 300 U - How heavy is it for trai in reply to El Toro, 08-14-2005 12:19:14
Depends on how its rated,but a C169 300U can pump out up to 42hp.(more with nitrous oxide...LOL,j/k).
