2 way to one way cylinder question??
John in Ct
08-14-2005 17:43:24
Can you hurt a new or just rebuilt 2 way hydraulic cylinder if you use it for one way (1 hose) operation? Hydraulic up, gravity down, proper breather vent. I know that they are used all of the time that way but I was wondering if there will be any dammage? Thanks!!
EricB
08-15-2005 04:38:44
 Re: 2 way to one way cylinder question?? in reply to John in Ct, 08-14-2005 17:43:24
Alternatively, if you have a remote return port and a quick connect on it you can run a hose from the back of the cylinder to the return port and it will keep it lubed all the time.
Janicholson
08-14-2005 19:17:55
If the upper half of the cylinder is lubricated with a squirt of hyd. fluid once a week, I believe it will be fine. I have seen a very well sealed piston allow the rod half to wear from no lube at bushing.
Jim N.
NDS
08-14-2005 18:18:55
Do not know if there is any damage but have used them that way 12 to 16 hours a day for weeks at a time and they held up fine.
