Farmall 450 fuel delivery problem
CLoud rider
08-14-2005 19:04:01
Got a 450 farmall that mostly sits. Went to use it this spring and it runs like it has a plugged fuel filter; will run under load for a minute or two and then start missing terribly; let it idle for a couple minutes and it"ll run for another minute under load and then start missing again. Only problem is there is no in line filter; is there a filter integral to the carb? thanks in advance for any help. Mark in MN
jossette
08-14-2005 19:48:09
 Re: Farmall 450 fuel delivery problem in reply to CLoud rider, 08-14-2005 19:04:01
what part of Minn???
Ernie Bob
08-14-2005 19:09:23
I would check the screen where the fuel line screws into the carb. It's a round screen the fits inside the carb before the needle and seat. It also could be the screen in the top of the sediment bowl.
Janicholson
08-14-2005 20:22:17
 Re: Farmall 450 fuel delivery problem in reply to Ernie Bob, 08-14-2005 19:09:23
Definately fuel delivery. Shut off the valve at tank, and remove the line going to the carb. There is a screen at this spot if plugged clean it and all the way up streem from there. Fuel should flow freely from the tube into a catch tray or can for a volume of at least a quart every two min. If not it is restricted in the lines or sediment bowl, or the pickup tube in the tank.
Where in MN are you, I am in St. Cloud Email me for a phone number.
Jim Nicholson
