Seal Kit For Char/Lynn Power Steering.....Where ??
W. Drew SMTA
08-14-2005 19:08:03
I have a leaky Char/Lynn slave unit on a 54 SMTA.....Does anyone know where to find a seal kit? Local IH dealer doesn't have a clue. I don't want a leaky unit on this tractor. It goes to the paint shop in Sept. and any issues of leakage need to be resolved before then. It has an eaton pump on it and I'm wondering if I should just plumb it into an on-demand-valve through the tractors hydraulics. The only reason that I question such a move is that the factory 2 point hitch is already plumbed into such a valve and I feel that this might look "Trashy" to try to plumb in another one. Any thoughts???
gene b
08-15-2005 19:48:51
 Re: Seal Kit For Char/Lynn Power Steering.....Wher in reply to W. Drew SMTA, 08-14-2005 19:08:03
Why dont you look them up on the net?
jonesy
08-14-2005 20:21:02
Force America sells everything from rebuild kits to complete new units and replacement parts for Eaton/ charlyn pumps
HFarmall
08-14-2005 19:48:20
I have had good luck when my local IH dealer could not help me is to take it to a Hyd. Shop ( where they rebuild Cylinders, Pump, @ Valve Bodys. They can cross reference seals, o-rings ETC. A lot of companies are long gone but there componets are still made. Hope this helps
jossette
08-14-2005 19:44:12
I got mine right out of IH. It is an Eaton Kit and have to tell them what serial number. Probably a S-101 or S-102 A through E. Part # 581.....
jossette
08-14-2005 19:43:57
