Super A PTO Help.....
scotty
08-15-2005 06:16:57
I have spent much time already trying to remove the two old seals from the pto. I have taken the whole unit off the tractor now. I believe I have to use a puller to remove the large gear from the pto shaft. After that can I just press that shaft from the inside out to remove the remainder of that seal? Any help appreciated. I couldnt find a blowup of that in my manual. Thanks.
scotty
scotty
08-15-2005 10:22:32
 Re: Super A PTO Help..... in reply to scotty, 08-15-2005 06:16:57
OK got it apart. I removed the engagement lever assembly that engages the pto first. Then was able to use a puller to remove the large gear from the pto shaft along with the woodruff key and then remove the shaft. Boy, that old seal was a bear to get out!!!! The new seal is nothing compared to the old one. Thanks.
scotty
Haas
08-16-2005 19:25:41
 Re: Super A PTO Help..... in reply to scotty, 08-15-2005 10:22:32
Well, you did better than I. I tried to drive the shaft out instead of using a puller. That won't work because the woodruff key catches on the housing preventing the shaft from coming out. Fortunately, I realized the problem before any significant damage was done. My experience, the gear came off fairly easy with a puller. Old thick seal is a challenge! New single seal works good. No leaks.
