Case IH
S Tate
08-16-2005 14:33:55
Am trying to find the specs for turning the crank shaft on a Case > Intn'l Harvester 284, 3cylinder diesel Nissan type SD 16. Can you help? Or where can I get parts?
Thanks!
El Toro
08-16-2005 14:54:13
 Re: Case IH in reply to S Tate, 08-16-2005 14:33:55
Your local machine shop should have the specs for your tractor. They probably can provide your bearings too. Hal
S Tate
08-17-2005 08:12:32
 Re: Case IH in reply to El Toro, 08-16-2005 14:54:13
We have checked all over the place and can't find either the bearings or the specs.
Thank for your reply. Will call around to some other shops.
El Toro
08-17-2005 15:59:40
 Re: Case IH in reply to S Tate, 08-17-2005 08:12:32
Have you had the journals measured? I may find out something on Thurs. I think std, and undersize bearings are available. My local machine shops do not have a 284 listed. I'll let you know something on Thurs. Hal
S Tate
08-19-2005 08:00:12
 Re: Case IH in reply to El Toro, 08-17-2005 15:59:40
Thanks, our shop found a repair manual on the internet, with the specs. This has been a challenge!!! Sammie
El Toro
08-19-2005 13:22:35
 Re: Case IH in reply to S Tate, 08-19-2005 08:00:12
I just received the fax on those specs. If you need them I'll post them. I think Case/IH will have bearings or they can get them for you. Hal
El Toro
08-19-2005 10:57:37
Glad you found the info that you needed. Good Luck. Hal
