350 Utility FLUIDS/OIL AMOUNTS
Josh Johnson
08-16-2005 18:43:32
I need to know the quantity of the various fluids that go into the 350 Utility and where they go in. What kind of oil? Where are the check plugs? (Excluding Engine in these questions)
TDK
08-16-2005 20:51:54
 Re: 350 Utility FLUIDS/OIL AMOUNTS in reply to Josh Johnson, 08-16-2005 18:43:32
Hyd. System holds appox. 13 1/2 qts. (13 3/4 if equipped with power steering)& is filled/checked underneath the seat. Trans/differential holds appox. 7 gals. & is filled on left side of gear shifter, checked at plug on left side of trans,under the foot rest.Independent PTO holds appox. 2 qts., check.fill plug is located on left side of pto housing. All the above use C/IH Hy-Tran fluid unless tractor has no T/A. In that case then gear oil can be used in trans.
