350 Axel size?
dhermesc
08-17-2005 07:50:11
Do ALL 350s have the same axel size as the "H"? I have a 350 with poor tires and one rotted rim. Have an auction coming up with a 1950 "H" that has been stripped for parts but has decent rear tires with good rims.
I know the tire is a size smaller but that doesn't matter as this tractor is mainly used for mowing and raking. Can't swap the rims because the 350 have the power adjust rims and the H has the deep well rims.
Dr.EVIL
08-17-2005 14:00:33
 Re: 350 Axel size? in reply to dhermesc, 08-17-2005 07:50:11
"cbl" is right. All H's had 2-1/2" dia. axles same as the std. axle in the 350. The Heavy Duty 350 axle was 2-3/4", same as the M.
dhermesc
08-17-2005 08:46:58
Thanks for the replies.
cbl
08-17-2005 08:20:55
The 350's had a standard axel that was the same as the H but they also had a heavy duty axel to help carry the 2M picker. I think the heavy axel was about like the M, not sure. I have one with the heavy axel and will measure it if time allows. I think it would be best to measure the axels before you buy.
Illinois Boy
08-17-2005 10:03:35
 Re: 350 Axel size? in reply to cbl, 08-17-2005 08:20:55
cbl,
I forgot about the heavy axle - THANKS!!
Illinois Boy
08-17-2005 07:55:22
I would say so - I know that the rear axle seals for a 350 will fit an H, 300, 330 and 340.
I don't believe there's a size difference for a 350 Hi-Clear from the row crop, but can't guess on the 350U.
