IH 234 Start Problem
G C Davis
08-17-2005 07:55:02
i have a IH 234 utility-when i go to turn on the key, i hear a click and it takes several times to get it to start. what is the problem? ignition switch or starter?
please help. its a good tractor - has nice woods belly mower and 6' blade and this year i just put new lug fluid filled tires on the rear. also where do i look to find out what the tractor is worth? i am wanting to sell it but i want to get the starter problem fixed first.
thepinkpanther
08-17-2005 11:04:34
 Re: IH 234 Start Problem in reply to G C Davis, 08-17-2005 07:55:02
i have two of those tractors and both have had the same problem. the click you hear is the electric fuel shut off on your inj. pump switching on and off.thats not the problem. the problem is....i am betting is one of the safety switches. the one on the pto or the one on the hi-lo nuetral shift lever. that happened to one of mine. the other tractor did the same thing and the problem was the plug in wire connection at the front to back wiring harnees connecting point.the connecter had became weathered and correded. you can adjust the safety switches closer or you might have to replace one of them.get out your test light and start tracing power. they are good tractors,but parts are HIGH! a wiring harnass is 300.00. are steering box is 650.00 exchange.whats it worth? how many hours,condition,attachments,and your location will determine price. here in sw mo everyone has full size tractors so the demand isnt great. in other parts of the country im sure it will be good stuff. barry
old
08-17-2005 08:27:56
Well if when you turn the key and you get a click lissen to where it is. If its at the soleniod then you need to replace it. But as Ill. says check all connections first.
John T
08-17-2005 08:27:51
GC, if it ALWAYS clicks at the solenoid when you try n start her but it takes a few tries before she cranks, AND ASSUMING THE BATTERYS GOOD??? Im thinking for now its EITHER a solenoid problem,,,,, ,,or a start switch/key problem,,,,, ,, or else bad connections like at the ground or battery cables or the starter or solenoid, but it still could be an internal starter problem like worn brushes.
First thing I would do is remove then clean n wire brush n reattach each n every battery n solenoid n ground n starter cable n connection then try her.
If it still persists, next thing I would do is jump a hot wire like from the solenoids big battery (NOT to starter) post over to its lil S activation terminal and see how well the solenoid performs then. When you have a key or switch in the START position all it does is send hot voltage down to the solenopids lil S activation terminal, so when you manually jump to that it can tell if the key or start switch is doing its job. If it like ALWAYS cranks when you jump to the solenoids lil activation terminal (thats says the solenoid is okay) but not when you use the key, I question the switch contacts!!!!! !!!!!
FINALLY, if she still acts up despite all good connections AND A GOOD BATTERY and despite jumping the solenoids activation terminal,,,,, its EITHER THE SOLENOID OR THE STARTER.
Its possible to by pass jump around the solenoid by jumping from its battery side (or direct from battery) over direct to the stater side BUT THATS A HIGH CURRENT AND HIGH ARCING SITUATION, BEWARE OF ARCING N BURNING, HAVE PLUGS REMOVED FOR EASIER CRANKING. Then if she ALWAYS cranks well that way BUT NOT WHEN USING THE SOLENOID, I suspect the solenod is bad/burned/carboned up inside.
John T Nordhoff in Indiana, retired electrical engineer who usually lurks on the Mother Deere pages versus over here on the dark side lol
Illinois Boy
08-17-2005 10:06:35
 Re: IH 234 Start Problem in reply to John T, 08-17-2005 08:27:51
Hey John,
Welcome to God's Country... : )
John T
08-17-2005 10:34:18
 Re: IH 234 Start Problem in reply to Illinois Boy, 08-17-2005 10:06:35
Thanks Neighbor, John T in Indiana
Illinois Boy
08-17-2005 07:58:07
Sounds like a battery post is corroded and need cleaning...
Battery is having to arc across the corrosion to complete a circuit. That's what I'd check first, then go to the solenoid...
