Order Farmall Cub Parts Online
International Cub Carb
Chrisfromsolitude
08-18-2005 15:32:50
I bought a cub from a guy who hasen't had it running for 4 years. The carb just spills gas out of it and floodes the tractor so bad it will only run for a few seconds then die. The carb is a Zenith 70949C-91. I called the local IH dealer and they said it is supposed to have a Zenith 71523C-92. I put the carb from my 48 on it and it ran perfectly. My question is what could the other carb be for? Also anybody that has an old cub carb I may be interested in buying it. Thanks.
Phlogiston
08-18-2005 16:50:43
 Re: International Cub Carb in reply to Chrisfromsolitude, 08-18-2005 15:32:50
What year is your Cub? Since you are calling it an International Cub rather than a Farmall Cub, I am assuming that it is a later model. The later model International Cubs did come with Zenith carbs. Not sure of the number though. Can your IH dealer order the rebuild kit for it? That is what it needs. Fairly easy and straight forward. Make sure the float is not hanging up along the sides, that can cause flooding as can a bad needle and seat. I would try that first before buying another carb. New Zenith carbs are still being made for your tractor.
Phlogiston
