Crankpulley
Matt Lobdell
08-18-2005 16:12:18
I have a 56" 200 with the 123CID engine. I am replacing the front crank seal, but I can not get the crank pulley off. Anyone who can help it would be appreciated.
El Toro
08-18-2005 19:22:26
 Re: Crankpulley in reply to Matt Lobdell, 08-18-2005 16:12:18
Hi Matt, You should have a puller made like this
using a hydraulic jack or a hydraulic ram like porto-power. These were made for a Cub, you would need to measure the hub of the damper pulley and the overall diameter of the pulley so your allthread would clear the edges of the pulley. Here's the website: Hal
PS: To reinstall place in your oven at 200 degrees.
http://www.ytmag.com/messages/459316.html
Dave_Id
08-18-2005 16:30:09
These are real tough ones to get off. Read all the info in the archives, but what it comes down too is lot"s of heat, and a very good gear puller.
Matt Lobdell
08-18-2005 16:31:57
 Re: Crankpulley in reply to Dave_Id, 08-18-2005 16:30:09
do you use the threaded hole in the middle of the pulley to reinstall it?
Dave_Id
08-18-2005 16:35:57
 Re: Crankpulley in reply to Matt Lobdell, 08-18-2005 16:31:57
It's a press fit. Heat it up, and slip it on.
