Carb Rebuild... Remove Old Paint
mrolson
08-18-2005 18:15:14
Getting ready to rebuild a carb. Will carb cleaner remove the old paint or is there a better method, don't want to gunk it up more that it is.
Mark
CNKS
08-19-2005 18:06:00
 Re: Carb Rebuild... Remove Old Paint in reply to mrolson, 08-18-2005 18:15:14
Rusty is correct. Disassemble and put everything in carb cleaner, not parts cleaner -- it will all come out clean, no paint.
Dave Sherburne,NY
08-19-2005 16:14:32
I use lacquer thinner it takes off the paint. I've got an Oliver 88 carb sitting in it now By the time the kit gets here I will be able to blow
everthing off.
RustyFarmall
08-18-2005 18:39:06
GOOD carb cleaner will remove paint and all the rest of the crud. If the cleaner you use does not remove the paint then you have wasted your money.
