Re: M Radiator
Janicholson
08-18-2005 18:57:42
My MD cap is rated at 6psi, however the manual should list the correct cap. A radiator shop can easily test the cap for relief setting. A splitting tank should have a copper reinforcement soldered on with at least 1/2" overlap on each side of a crack/split. Solder has no strength as a crack filler, especially on a flat area of a top tank.
I'd say it was the shops responsibility to make it right. it is not trivial to remove the radiator!!
My opinion,
Jim Nicholson
mrolson
08-19-2005 05:56:15
 Re: M Radiator in reply to Janicholson, 08-18-2005 18:57:42
Thanks for the replies. And I am now very good at removing the radiator!!
