Suggestions for purchase of a tractor!
Kent H
08-19-2005 08:33:28
I am looking to purchase a tractor. Will be used to plow a large uphill driveway, pull a mower and maybe a cut/bale 10 acres of hay. Currently own a WD45 WF with a loader, will be selling it as no power steering, no 3pt & would like a little more power. Would like to spend around $5000-$8,500, any help would be appreciated.
gene (Missouri)
08-19-2005 20:57:38
 Re: Suggestions for purchase of a tractor! in reply to Kent H, 08-19-2005 08:33:28
Am I missing something. A 3-point adaptor for the WD45 costs around $250- to $400-. I own several of the WD series Allis' (also a number of IH tractors)and they are not hard to steer - just take the off loader or drop off the bucket.
My first, last and middle name is cheap. I sure wouldn't spend $5000- to $8500- to replace a 45 horsepower tractor with live PTO and live hydraulics to mow and bale 10 acres.
Gene
Kenth
08-23-2005 13:29:58
 Re: Suggestions for purchase of a tractor! in reply to gene (Missouri), 08-19-2005 20:57:38
Gene,
Thats cause you have not plowed enough minnesota snow. Trust me you dont want to spend an extra a bunch of extra time (fighting with no power steering) in the snow, ice, and cold :)
Kent
Don L C
08-19-2005 17:40:17
Kent --- there is a nice IHC 460 D, forsale listed under Photo Ads, Ad #110500----- go to photo ads and put this ad number in the search box and click on srarch.....Don S.W.Ohio
kentH
08-23-2005 13:13:28
 Re: Suggestions for purchase of a tractor! in reply to Don L C, 08-19-2005 17:40:17
Don,
Thanks for the information. I was looking for a wide front.
Aberdale Farm
08-19-2005 14:55:29
If you are devoted to red, then I would consider a 706/806 diesel. Actually, an 886,986, 1086 would be better if you are interested in a cab tractor, but will probably be pushing the top end of your price range.
If you are not picky on color, a JD 3020/4020, or a Massey 165, or Allis 190XT, or Oliver 1750/1850/1855 would all be good choices for all around tractors with good horsepower. I would definitely consider diesel instead of gas in all of the above choices.
Good luck!
Dale
Dellbertt
08-19-2005 14:29:31
I know this is the wrong page for this sugggestion but I think a Case 930 or 1030 is the best and cheapest horsepower going. IF you find a good one. I paid $800 for a 1030 that had been setting for 5 years and it runs terrific and does not use oil. For snow plowing the IH Utility series are TERRIFIC. Go slow and the right deal will find you.
caseyc
08-19-2005 09:17:34
as long as your not doing any heavy tillage work a 656 sounds good. any 06/56/66 would treat you well. a 656 hydro would be the cats a$$ for everything you decribe.
casey in SD
Kenth
08-23-2005 13:20:46
 Re: Suggestions for purchase of a tractor! in reply to caseyc, 08-19-2005 09:17:34
Thanks all for the help.
I purchased a 1964 Farmall 706D with the 282. New rear tires, TA, clutch & paint for $4,200.
Think the price was right?
Still need to find a loader to go with it.
Thanks again, Kent
jakee
08-19-2005 16:31:03
IH- 574 another good tractor,i put a 3-point on a H and it does everything i want it to
