ihc706
daron
08-19-2005 14:56:05
i have a 706 with 310d. It needs a thermostat but i being unable to find. Does anybody have any idea"s thanks inadvance.
El Toro
08-20-2005 05:09:16
 Re: ihc706 in reply to daron, 08-19-2005 14:56:05
I called a Case/IH dealer in Delaware and they have 7 of those thermostats for the 310D. You can email them at dbigelow@hoober.com. Their toll free number is 1-800-341-4028. The price is $18.16. They didn't have the gasket, but could order it. You could probably have it drop shipped to you. You need to ask for farm tractor parts since they have garden tractors too.
Hal
MN Scott
08-20-2005 19:05:15
 Re: ihc706 in reply to El Toro, 08-20-2005 05:09:16
Those would be the new style thermostat. They are the automotive type. 706 and early 756's had a thermostat built into a tin housing that connected to the water manifold, water pump carrier and the upper radiator hose. The thermostat was not removable and you had to buy the complete housing. They are no longer avaiable from CNH. My dealer did a search and found non in stock in the US. The last price for them was $88.50.
the tractor vet
08-20-2005 14:16:14
That thermostat does not requier a gskt. as it goes into the hose between the engine and rad.
El Toro
08-20-2005 04:39:25
That email that I gave you isn't in service or I copied it wrong. Try this one it will go to the same place. Hal
info@ihc.de
El Toro
08-20-2005 04:20:36
Try this email to see if they have a thermostat. Hal
mbush@freenet.de They're in Germany.
the tractor vet
08-19-2005 18:57:56
They don't make them anymore and all i can say is good luck , you will have to find a dealer that has a new one on stock and i have know idea other then Clyde Burkshire in Royal Center Ind.
Bob
08-19-2005 20:44:09
 Re: ihc706 in reply to the tractor vet, 08-19-2005 18:57:56
I have a 706D, but not with the German engine, so I am not familiar with that thermostat.
What is special about it... I suppose it has a block-off plate for the recirculation circuit on the bottom, anything else specific to this application?
MichaelNEIowa
08-19-2005 19:57:22
I'm surprised that parts for that engine would be so hard to find.
Are there any other "common" IH engines that we should start hoarding parts for?
What about engines to avoid because parts are no longer available/hard to find?
El Toro
08-19-2005 16:04:08
Have you tried Case/IH? NAPA may have one too.
Here's a website that shows a thermostat for the 706. P/N S-61470 Hal
http://www.cefs.com/caseih1.hmt
daron
08-19-2005 18:05:59
 Re: ihc706 in reply to El Toro, 08-19-2005 16:04:08
tried both they don't make them anymore
El Toro
08-19-2005 18:42:17
 Re: ihc706 in reply to daron, 08-19-2005 18:05:59
Did you try the website in Canada? Hal
