Hydraulic block gasket sealer
stillredjohn
08-19-2005 18:28:22
When installing gasket on hydraulic block on Super A, do I need to use some kind of sealer or just install dry? I have the head and block scrupulously clean. All help greatly appreciated. John
CNKS
08-20-2005 09:47:37
 Re: Hydraulic block gasket sealer in reply to stillredjohn, 08-19-2005 18:28:22
I did not use it on mine because of all the openings the sealer could possibly get into and mess up the hydraulics. Just get it absolutely clean and use the proper torque specs, which I believe is 45 lbs. I use sealer on about everything else, though.
tn terry t
08-19-2005 18:45:52
i never have used any sealer on mine
