Super C Final Drive Seals
Duane H
08-19-2005 18:42:20
I need to change the final drive seal in my super C. I am getting a lot of oil leaking from around the axil. From the drawings in my IT manual it looks like I can do this without having to take the top cover plate off of the transmission. I think I can just pull the axil housing off of the transmission case and leave the axil and final drive gear connected. It looks like the final drive gear will drop down but I think I can realign it when the axil housing is put back on. Any of you guys ever done it this way? Will it just be easier in the long run to pull the transmission cover plate? Thanks for the help.
Duane H
08-20-2005 09:03:26
 Re: Super C Final Drive Seals in reply to Duane H, 08-19-2005 18:42:20
Thanks for the advice. I thought I could get by easy but I guess not.
Jim J
08-20-2005 07:16:47
I"ve pulled many axle housings off of C"s with out taking the top off. First you need to pull the PTO off and then reach in through the hole in the back of the casting and take the 2 bolts out of the end of the axle. Next take the housing loose and pull it off.
gene b
08-20-2005 01:52:27
You have to remove the top cover to do this and while you are apart maybe want to do the front seal also.
Wayne Swenson
08-19-2005 20:57:23
Pull the top cover; it is the only way to do this task!
CNKS
08-19-2005 20:06:11
The seal that leaks is the inner seal, the outer one is just a grease seal. The bull gear has to come off. On the H/M you can do this thru the PTO housing. I have done the C and H by removing the trans cover -- others may have other ideas.
Andrew Z
08-20-2005 13:46:28
 Re: Super C Final Drive Seals in reply to CNKS, 08-19-2005 20:06:11
I just did that last month and its not the easiest job. But I would say after doing it you should remove the top cover. It will make life easier in the end. Good Luck Andrew
