Overunning Clutch Opportunity
SuperCmore
08-20-2005 07:08:16
Finally got an overunning clutch for Cmore, put it on, and my fast hitch brush hog pto shaft won't fit. It's about 4 inches too long. Should I just cut the shaft off, what could I be missing here?? Hate to cut the shaft, but will if I have to. Thanks, Cmore
Hayfarmer
08-20-2005 08:34:59
 Re: Overunning Clutch Opportunity in reply to SuperCmore, 08-20-2005 07:08:16
I had to do that on mine. If it won't fit with the additional pto length then there is lots of overlap in the pto. Should be enough for a standard length pto later. Otherwise move the overrunning clutch over with the shaft.
Van in AR
08-20-2005 07:43:24
If you want the overrunning cluttch you will have to cut the shaft.
Van
