43 Farmall M starter
Hawki97
08-20-2005 18:11:51
I just put a "new" starter on my "43 Farmall M. I"ve run into one problem: the starter I removed had a bolt that went through the circular connector at the end of the positive line that bolted the line to the starter. No such place exists on the new starter. There is a copper looking nub on the side of the starter that is flat on two sides and curved on the two ends. I tried to remove it from the starter housing thinking that is where I would bolt the hot line, but turning it did not remove it. Since there is nothing else (apparently) to attach the line to, I"m confused as to what I do to attach the hot wire to the starter. Help!!!
MagMan
08-20-2005 18:21:27
 Re: 43 Farmall M starter in reply to Hawki97, 08-20-2005 18:11:51
I have been known to be wrong on a few ocasions but it sounds like thats the newer style starter that had the push butten switch on top of it and a remote rod would push against it from back where the steering colum is is. I would say that you need an older style starter. JON
RustyFarmall
08-20-2005 18:57:01
 Re: 43 Farmall M starter in reply to MagMan, 08-20-2005 18:21:27
That's pretty much what I am thinking also, what you have is for a super M.
