Av-Gas
On2Wheels
08-20-2005 20:22:37
Can anyone give me the straight story about Av Gas? I have been using it in my Farmall M. My M will not stop running on anything less than 100 octane. Av gas seems to do the trick. I only use this tractor for pulling and it is pretty much stock. Except the high compression head and step pistions.
Thanks.
RAW in IA
08-21-2005 11:48:48
 Re: Av-Gas in reply to On2Wheels, 08-20-2005 20:22:37
The higher octane will help keep from detonation, which is what is causing the M to diesel when you shut it off hot. Unless you have a super high compression ratio I don't think it is neccessary to use the higher octane. Av gas is 100 octane and has lead in it. The best way to eliminate the run-on is let it cool down befor shutting it off. Also, the newer IH tractors had an electric solenoid on the Main adjusting screw on the carb that would shut the fuel off completely when the switch was turned off. I don't know if theat could be put on an M or not.
