Super C drawbar / drawbar support
leon
08-21-2005 03:30:40
Saw a Super C with the more usual swinging drawbar support that bolts to either side of the rear of the diff case. But, along side, not yet attached was another drawbar or drawbar support that clamped around the rear axles and was a big "U" shaped strap that goes around the smaller support. The drawbar itself wasn't on the tractor yet either but it looked to be adjusted to be long enough that perhaps it was supported by both the inner and outer drawbar supports. Have I got this figured out about right? Was this outer "U" shaped strap/support/drawbar an option? How common was it or did all Super C's have it?
CNKS
08-21-2005 12:03:19
 Re: Super C drawbar / drawbar support in reply to leon, 08-21-2005 03:30:40
The U shape is the H/M type drawbar, it was not sold on the C but will fit -- I have seen sickle mowers attached to a C with the U shape.
