B Farmall Wiring
Chad Wedell
08-21-2005 11:17:00
I got my tractor rewired, according to the diagram sheet. Where does the switch fit in to the plans? & When the tractor is running the ammeter shows discharging.
Any help for me.
John T
08-21-2005 15:31:25
 Re: B Farmall Wiring in reply to Chad Wedell, 08-21-2005 11:17:00
Chad, when shes not running if you turn on any lights or ignition (if it has a coil ignition) the ammeter, IF WIRED CORRECT should swing to discharge. If it swings to charge, its leads may well be wired bass ackwards.
John T
jostev
08-21-2005 14:12:09
You may need to polarize it.
gene b
08-21-2005 13:13:44
What are you using for ground? Original was POSand if you are using a regulator you better check the reg to see which ground goes with the regulator.
Dellbertt
08-21-2005 12:43:50
duh you got the wires bass ackwords on the ampmeter.
