Farmall Plow Mount?
KirkMn
08-22-2005 05:30:09
I picked up a plow for my "A" off of Ebay. The guy said it was taken off a model B. Can any one help with identifying the Mount. It looks like some kind of lowering kit for a taller tractor.
The Pic of it is in the Help Identify photos under Farmall Plow Mount.
BTW I got it for 20 bucks so if it wont work Oh Well!!!
JohnG(TX)
08-23-2005 15:16:04
 Re: Farmall Plow Mount? in reply to KirkMn, 08-22-2005 05:30:09
I have the manual for this plow, and I think it only goes on the Super A, but I would have to check. To mount it on the A, you will need a set of brackets that will mount the plow in place of the drawbar. If you are interested, I could look up the number of the plow and send a scan of the brackets.
gene b
08-22-2005 19:49:49
The mounting stuff for the B is quite different than the A. You will need lots of parts to mount it on the A. I do have some linkage for the A but the beam is different also so i dont think you could make it work.
El Toro
08-22-2005 14:29:59
I restored an A that came with a 16-inch moldboard
plow. The beam and brackets sure looked different than your plow. I have picture if you think you may need it. It would just show the area where the brackets attach beneath the tractor. Does a good job plowing. Hal
