Carb adjustment
Carlton
08-22-2005 09:51:33
Hi there ,I have a farmall 300 row crop and was wondering what the three adjusters were on the carb,there is one on the front,one on the upper font ,and one on the side? Carlton Clancy Montana
CNKS
08-22-2005 17:26:23
 Re: Carb adjustment in reply to Carlton, 08-22-2005 09:51:33
Just so we get the locations correct, from top to bottom: Idle speed, idle mixture, main (adjusted at wide open throttle) mixture.
FarmerSid
08-23-2005 05:09:21
 Re: Carb adjustment in reply to CNKS, 08-22-2005 17:26:23
Just to add to what CNKS has said. I think the carbs on the 300 and 350's are the newer style. The idle mixture screw is on the flange where the carb bolts onto the manifold a little higher than the idle speed screw. The older style carb has the idle mixture screw below the idle speed screw. It is pointing down on an angle. Either style of carb, both the idle mixture and idle speed screws are on the top half or throttle body portion of the carb. The idle speed screw will always be the one that is inline with the tube that connects to the govenor. The high speed or main jet screw is on the bottom half or bowl of the carb. Hope this helps ya.
Cheers!
Sid
