should I use pos or neg ground?
Paul G. in Mn
08-22-2005 15:17:40
I am restoreing an F-20 and installed electric start on it. I am not going to run a generator or altenator on it. I am putting in a 12 volt battery so it starts faster with out running the battery down. I am wondering if I should go pos or neg ground on it. Thanks Paul
Nebraska Cowman
08-22-2005 15:32:25
 Re: should I use pos or neg ground? in reply to Paul G. in Mn, 08-22-2005 15:17:40
Don't make a bit of difference. i'd hook it up negitive ground, that way if someone helps you jump it sometime there is less likely for mistakes.
