tractor wan't start
ugly jim
08-22-2005 16:08:35
hey guys how's it going,couldn't get my tractor started the past couple of days tried jumping,took battery out of my truck, and even put a new battery in it and all i get is a slooow turnover, checked cables and all other connections and all seems good, you fellas always have good answers i myself cant figure it out, oh by the why it's a 966 diesel with one battery sure could use the help thanks ulgy
El Toro
08-23-2005 08:56:44
 Re: tractor wan't start in reply to ugly jim, 08-22-2005 16:08:35
You can get new batteries from Sam's Club. Here's a website for new cables. Hal
Link
http://www.classicandexotic.com/catalog/electrical/misc0028.htm
GordoSD
08-22-2005 21:17:53
966D with one battery? What's in the other battery box? You need TWO NEW BATTERIES! Never replace just one. These old 966's should start before you can even get your thumb off the button.
But if one of those batteries is shot you don't have a prayer. It will cost you 180 bucks but your tractor will come to life whenever, whatever.
Gordo
K.B.-826
08-22-2005 17:29:19
You need more battery! Should have two big 950 CCA 6-volt batteries in series. Two 12's in parallel can also be used, like an 86 series. If you have ANY doubt about the battery cables, replace them. They may look clean, but they're probably corroded on the inside. They need to be very heavy, at least 2/0. It's amazing what a difference new cables make.
Allan in NE
08-22-2005 17:39:17
 Re: tractor wan't start in reply to K.B.-826, 08-22-2005 17:29:19
I agree,
Get 2 new batteries and new cables before you burn that starter up.
Allan
Janicholson
08-22-2005 19:21:34
 Re: tractor wan't start in reply to Allan in NE, 08-22-2005 17:39:17
If (and only if) the battery/s are not at fault as pointed out correctly by Allan in NE. The starter could need a rebuild. The bushings can be worn enough to allow the armature to drag on the field poles causing radical amps not much turning. I've also seen shorted armature to ground cause slow spin. With hot battery/s and good cables/solenoid, slow cranking is a bad starter.
I hope they are correct.
Jim Nicholson
